Rhino on Linux?
Just like Wine has apps that don’t run well on it, so does Raven. It needs more time to mature.
I had installed RH8 on Ubuntu 26.4 LTS last month. It took me like 8-10 hours with the help of ChatGPT to correct some thing after the installation. Mainly they were display issues related to the NVidia driver or the compatibility issues with Wine. It got to a point where I can work with it but still some things are not working as good as on Windows and the general performance is slow when you compare it to Windows. But in an emergency I have it up and running. It is just not as nice looking as Windows.
I invite you to try out the patches then :smiley: GitHub - Jabern/rhino-linux: Patches and scripts to get McNeel Rhinoceros running on Linux using Wine and DXVK. · GitHub
it shouldn’t take more than 10 minutes ( depending on your internet speed and hardware specs of course )
You can look up a little bit in the answers you will see that there is a big improvement over stock wine experience :blush: and if there is any problems please feel free to write them down over here or in private messages or in the github issue page
Thank you for this script. It worked well. Rhinoceros v9 on Fedora 44:
P.S: McNeel should put on the System requirement, that it runs on Linux using Wine.
If they do that, they will need to provide official support to it, and I don’t think we are at that level yet
@Mohammed_Jaber Been working all day and no crashes so far. One weird thing that happens is when I go to a print layout, in Rhino 8 (opengl), antialiasing stops working - even if I go back to modelling viewports, AA is still off. In fact, AA option dropdown is empty in Options\View\Opengl - I have to go to Options\Advanced\Rhino.Options.OpenGL.AntialiasMode and set to 2.
In Rhino 9 WIP, the same thing happens using opengl, but not when using directX.
It also affects the PDF if I print with Raster.
On looking closer, it doesn’t look like anti aliasing is turned off - but more like the alpha channel is broken or something like that - it actually looks worse than having AA off.
@Cumberland That’s great ! i’ll be waiting for your feedback :smiley:
To add to what @altamiro.aj said, McNeel cannot provide support for a behaviour as unsupported as running a Windows software that rely’s a good chunk on dotnet under Wine, it’s the job of the community to keep it up and running :smiley: ( but if McNeel keep adding more Webview2 depending UI i will loose my mind :laughing: )
@gavinmetzler Thank you for the repport , i will look into it today, i’m having a lot of troubles with OpenGL to be fair, Rhino 9 was very straight forward thanks to DXVK, the performance were acceptable out of the box but for OpenGL i had to do some dubious hack fixes for Rhino 7 and 8 to work without sticky viewport or weird rendering pipelines bugs, also could you please share your hardware detail ? thanks :smiley:
I tried switching to Rhino 9 WIP, but its freezing/crashing a lot. Rhino 8 has been completely stable so far - about 10 hours straight work so far. Whereas 9 I can’t work more than about 10 minutes before it just freezes.
Rhino 9 is out in a quiet soft launch btw. :stuck_out_tongue:
I will look into it, thanks to everyone who is testing and reporting bugs , you are amazing ! :smiley:
V1.4.2 is out !
There is a lot of performance improvement and bug fixes :smiley:
for updating please download the latest flatpak as i changed a lot in the launcher and changed the update mechanism.
Still open : Rhino 9 is unstable due to the Webview2 gpu compositor, i’m still working on it :slight_smile:
Also, i’m making public the other side of the project which is making Rhino work under ARM and in Android :
Unfortunately i don’t have hardware to work with an got forced to use my crumy Samsung A24, so i’m planning to buy a flagship phone or tablet to work with as well as a snapdragon powered laptop, thanks everyone for the support and feedback !
if you wish to help me out to buy some hardware you can do so via github sponsorts :blush: Sponsor @Jabern on GitHub Sponsors · GitHub
Affinity just announced that they are indeed working on a native Linux version. No release date yet, just work in progress atm. I guess they are feeling the pressure from those ArtCraft apps.
Hi Mohammed,
Thanks for the update. THere seems to be a regression with the antialiasing issue in 1.4.2, where going to print layout breaks antialiasing. I manually reverted to the wine-rhino-11.20-x86_64.tar.xz from 1.4.1
Also, I don’t know if this is just me and the way my filesystem or permissions are setup - I’m not a linux expert - but when I go to save any file in Rhino 8 over itself - if I open a file, make some edits, and click Save - I get an error that it can’t be saved because it was opened in read only. It actually deletes the file, and if I click Save again, it works. If I don’t click Save again, my file is lost, so its rather dangerous.
Remember that Affinity bragged about not being acquired on social media just two years before they got acquired so I wouldn’t trust anything they say or do these days:
Right now they’re owned by a shitty AI corporation that just fired 22% of its staff:
That is the general rule of tumb when it comes to tech giants. How many products have Google itself discontinued? Microsoft too.
However, I do believe that there will be an influx of Linux support because in every company there is a developer that is a Linux guy, and with the AI assistants he will be able to do the work of 5 devs and start working on it. Sadly, this posts seens to have a lack of McNeel employee’s participation :frowning:
Oh, they’re here, but only reiterate they’re not working on it (even though Linux has roughly the same market share as MacOS these days).
Then again, I would not want a slop shovelware version of Rhino on Linux, nor would I want en Electron conversion like Plasticity did (even though it works).
I don’t want to go into stereotypes, but isn’t developing for the Linux user a PITA? Putting technicalities aside, OG Linux users seem to want to do things their way, and they praise open-source projects - which in itself is a good thing, but not necessarily if you want to sell them closed-source commercial software. Many of them might go to great lengths to stick with the open-source alternative, so all that effort to support a plethora of different Linux users could be not all that convincing. And one extremely happy Rhino&Linux lover still buys the same amount of licenses as when he was using Rhino on Windows.
Saying all that, that might already have changed, and it’s still changing as we speak. More and more, “regular” users are looking for some stability and safety, and whether their concerns about privacy are legitimate or not, they might be willing to spend money on software, but in their new safe shell.
I agree with ou but, how much of that market share is “Design firms” and “architects” and stuff? I think that maybe the MacOS “useful” market share must be bigger, and of course, there is Bob, I have heard that we have iRhino on the apple devices because Bob itself asked for it since he uses it :stuck_out_tongue: not sure if its true.
We need to get Bob on Linux then. Someone send him an arch install-stick
Arch is the one that is heavily customizable isn’t it ?
How hard is to convert its entirety into Rhino inspired stuff? Imagine not only having Rhino in Linux but having a Rhino inspired Linux customization :slight_smile:
