SR7 is available for some time but Rhino always says I have the latest version when I check for updates.
Any clues ?
Regards
Any clues ?
Regards
I had this problem too. Try a manual update check - see also
I also had an older version, either SR5 or 6, but my rhino did not give any news of updates either, and when opening the “check for updates” it also displayed “up to date”.
I also had to click the link in said menu “check for updates” and it found a newer version.
Thank you for your suggestions, I will download the update manually.
Regards
I’ve just published a new SR7; you should see automatic updates showing up now. Please let me know if you don’t.
It works now, upgrading from the previous SR7.
Apart from this issue, is there a list of changes w.r.t. the previous SR7?
Correction, It seems to all work now.
Hi Menno,
The only change from the previous SR7 was a fix to the evaluation mechanism - Rhino incorrectly failed to load all our built-in plug-ins after expiring. This won’t affect anybody but new users.
Yes, Rhino just self updated to SR 7 …Great !
Hi Todd,
You are on the latest update of Rhino 7 already.
