The Rhino SystemInfo command won’t see anything else that’s useful.
Windows is not using the right driver for your gpu(s).
Basically, your computer is not setup correctly.
Instead, please run the Windows Device Manager and expand the Display adapters section.
A screenshot of that would help.
This problem happens every time I come back home when I’m at campus everything works just fine maybe it is the way I’m setting up the pc here at home I think.
If it were me, I would run the Windows Check for Update command.
Download and install everything, reboot, and run Check for Updates again.
Keep repeating until Windows says it’s fully up to date.
Are you connected to some sort of docking device?
If so, try disconnecting from that and restart.
My guess is then the Display adapters will show an Intel CPU.
That would indicate this is a Hybrid computer.
These instructions will help sort out that mess:
