Rhino + Morbidelli M100: own CAM post + digital twin, 3D model?
Hi all,
We own a Morbidelli M100 (5-axis nesting machining center, bought through DKSH
Japan) and have been running it for about a year. We design our parts in Rhino and
are writing our own CAM / post-processor that outputs the M100’s native .PGM —
together with a small toolchain for interference / collision checking and
machining simulation (essentially a digital twin of the machine).
Before I reinvent the wheel, I’d love to hear from anyone who has gone down this
road:
  1. Machine 3D model / kinematics
    • Has anyone obtained a 3D CAD model of the M100 (STEP / IGES) from SCM or
      DKSH, or built one for simulation? Even a simplified enclosure-level model of
      the gantry, spindle/aggregate head and worktable would be useful.
    • If you set one up in a machine-simulation tool (e.g. Vericut), how did you
      get the axis travels, spindle/aggregate offsets and tool-changer positions?
  2. Post processor / output format
    • My understanding is that the M100 runs a binary .PGM, and that a text
      program (.xxl) gets converted with WinXIso. Is that still the current
      workflow? Any gotchas people have hit?
Any pointers, sample files, or “don’t bother, do this instead” advice would be
hugely appreciated. Happy to share back what I build.
Thanks!
Hey i am a german based Carpenter and currently writing a Quick CAM for a old SCM Record 240 from around the 2000’s.
  1. yeah i also use WinXIso to get .pgm from .xxl no problems so far.
I started to create the CAM simply because Layer based .dxf import is to limited and Xilog Plus is really oldschool and if you are not a 50 year old g-code crack, pain in the ass. A lot of repetitive typing… Smaller furniture shops like to use these big old rigid machines (cheap) but need a “quick and dirty” CAM with visual control.
Happy to share some experience even if you are 1 CNC generation above.
i’ve set up a rhino plugin, that enables Rhinocam to export .xcs (maestro scripting language)
This allows external toolpath / fabrication planing - but allows checks in Xilog Maestro.
“MSL *.xcs files can be directly imported and tested in Maestro”
Referring to your second question - this is a screenshot of an official scm presentation:
hope this helps - kind regards -tom
I do work with both Maestro/Xconverter and XilogPlus/WinXiso.
Haha, very nice to know there are people that i can talk about it. Always felt like a lonewolf.
Right now i am working on a App that runs rhino headless in the background and auto imports saved dxf/step files, interpretes the 3D-geometry for toolpath generation and it outputs a 3dm for post edit and a xxl/pgm.
Only for simple operations, otherwise you need a “real” CAM, but a lot of furniture shops are bad in adopting to new CAD and overwhelmed by Rhino. So rhino is a option for post edit the path but can be skipped. Or the shops have 1 or 2 pros in gcode who will just work on the pgm manually.
So i am trying to fill the space as a stable easy and quick converter for people without much knowledge, so more people in the shop can use the CNC for simple taks without the specialized Operator.
Please share your experience :slight_smile: @Tom_P @Cumberland
Hi everyone — thank you so much for all the replies. It’s genuinely encouraging
to find others working in this same small niche; I didn’t expect this corner of
the CNC/furniture world to have so much shared experience.
@mi.land — great to hear from someone taking the same path. Your headless-Rhino
approach (DXF/STEP in, toolpaths out, exporting both .3dm and .xxl/.pgm) is
almost
exactly the architecture I’ve landed on, so it’s very reassuring. And good to
know
WinXIso handles the .xxl → .pgm step reliably for you as well. The motivation is
the
same on my side: Xilog Plus and the like are too heavy and dated for a small
shop,
so a stable, quick converter that people without deep G-code knowledge can
actually
use is exactly what I’m aiming for.
@Tom_P — thank you for the RhinoCAM → .xcs (MSL) tip and the SCM presentation.
Being able to import and test .xcs directly in Maestro is very appealing, and I’m
now looking into the MSL route as an alternative/complement to the .pgm path.
@Cumberland — thanks for confirming you work across both Maestro/Xconverter and
XilogPlus/WinXiso. Good to know both toolchains are viable in practice.
A quick progress update: I’ve reached a first milestone — PGMX output is now
generating successfully, though still at a test stage. It’s early and needs
plenty
of real-machine validation, but the core pipeline (geometry → toolpath → native
output) is now working end to end.
The one thing I still haven’t managed to get is a 3D CAD model of the M100 itself
(axis envelope, tool-changer positions, etc.) for the digital-twin / simulation
side. If anyone has such a model, or knows a good place to source one, I’d be
very
grateful — that’s currently the main blocker for the simulation part.
I’ll keep sharing progress here. Thanks again, everyone!
