I’m looking for an experienced Rhino modeler to turn 30 concept designs for marble tables into fabrication-ready models for stone CNC manufacturing, and to render a 360° turntable video of each object from the final models.
The work: 10 designs, each in three sizes: dining (Ø150 × H75 cm), coffee (Ø100 × H38 cm) and side table (Ø55 × H50 cm). The forms range from organic to faceted and geometric. Concept renders, dimensions and design intent will be shared after signing an NDA.
Deliverables per object:
1. Production model
– Watertight solid models in Rhino 7/8 (.3dm), mm units, organised layers; STEP/IGES/STL exports
– Split into fabrication parts (slab tops, block bases) within realistic block and slab sizes, with joints, pins and top-to-base fixing
– Machinable geometry for multi-axis CNC (tool access, minimum radii, no impossible undercuts)
– Weight per part, with hollowing where appropriate; stability or stress concerns flagged
– Size variations developed properly, not uniformly scaled (consistent top thickness and support proportions)
– A defined area for a carved inscription
2. Technical documentation
– Dimensioned 2D drawings (PDF + DWG): plan, elevations, sections
– Exploded assembly view
– Parts list with dimensions, volumes, weights and required block/slab sizes
3. 360° turntable
– One slow, seamless full rotation (~15–20 s), 4K MP4 master + web-optimised version
– Neutral light background or transparent alpha, with soft contact shadow
– Identical camera, lighting, speed and scale across all 30 objects
– 72-frame PNG image sequence (every 5°) for an interactive web viewer
– Photorealistic honed marble, with veining continuous across parts; real slab photos may be supplied
Ideal candidate:
– Proven experience modeling stone or marble pieces that were actually fabricated (please share examples)
– Strong SubD-to-NURBS workflow for organic forms; Grasshopper a plus for the size variations
– High-end product rendering (KeyShot, V-Ray or similar), with turntable examples
– Experience working with stone fabricators or CNC shops
Process: paid pilot on one design (3 objects, all deliverables including turntables), then the remaining 27 if it goes well. Full IP transfer and NDA required.
Please reply at +306978114691 whatsapp with: portfolio links (fabricated stone work and turntable renders), your price per design, revision policy and estimated timeline.
