Rhino memory leak problem
Hi. I am running the latest version of Rhino on Mac OS Catalina 10.15.1
I have an outline and a plane. Did a command to split the plane in two pieces using the outline.
Message : Your System has run out of application memory.
Only Rhino running, no other applications.
Rhino ( not responding) using 63.81 GB
Finder 11 MB
Someone told me that it seems like Rhino has a “ memory leak”
How can I fix this?
Christoff
does it happen with all files or just this one? How much ram does your machine have?
please run the systeminfo command in rhino and post the result-
Hi , thanks for the reply
I have 16 G ram.
It happened with this file.
The original file was a DWG with problems.
I am trying to re-create the file for laser cutting.
I need to make it a solid so I can make a rendering so I have an image to auto trace in another program.
I wish there was an easier way ( like live paint in Adobe illustrator)
But Rhino is al I have.
( My illustrator stopped working since Catalina came) :confused:
Hehe for you Illustrator Problem (not for your RAM problem)
Try Affinity Designer - a nice illustration tool together with Rhino.
I also killed my CS6 with catalina and thanks to affinity I am happy with this.
My Rhino does not have a command “Systeminfo”
Unknown Command: Systeminfo
Closest is “SquishInfo”
Can’t be that.
Thanks Hugo, will try that.
The end of it was I left Rhino to do it’s thing. Hours later It seems that Rhino quit or crashed and closed the file without saving any results of what I tried.
Back to a line drawing- no surface was saved.
I think Rhino crashed- but without giving me a notification that it crashed.
