ko11
(ko)
August 17, 2026, 1:01am
1
hi
i was wondering why my laptop was so slow the past ~week and found these two processes were using all my ram
here is a sample of the 4746 one (the other had quit—maybe when i disabled the extension in claude)
Sample of rhino-mcp-router.txt (153.0 KB)
(rhino is not open)
Thanks for reporting, I’ll have to look into this
YT : RH-97810 Rhino MCP router grows to consume all memory
ko11
(ko)
September 5, 2026, 1:08am
3
btw this persists
i hadn’t experienced it since disabling the connector in claude, but i re-enabled it yesterday to ask some gh2 questions and today i am faced w/ the leak again
rhino is closed
two processes again, here are samples of both:
Sample of rhino-mcp-router 2.txt (71.4 KB)
Sample of rhino-mcp-router 1.txt (71.3 KB)
I believe this PR will fix the issue, thanks for reminding me. I’ll release a new version soon so this issue is resolved for you.
rhino-9.x ← callum/9.x/memory-leak-watchers
opened 09:14PM - 05 Sep 26 UTC
Fixes https://mcneel.myjetbrains.com/youtrack/issue/RH-97810
Hey @ko11 ,
Could you try this pre-release version 0.3.0 and let me know if it solves your problem. Your current Claude Desktop connector should not need updating.
rhino-mcp-platform-0.3.0-rh9_0-mac.yak (14.9 MB)
ko11
(ko)
September 7, 2026, 3:54am
7
ok so it happened again
Sample of rhino-mcp-router 3.txt (71.0 KB)
but the process is still …/packages/9.0/Rhino-MCP-Platform/0.2.1-wip /router/osx-arm64/rhino-mcp-router
is that right?
package manager says 0.3.0 is installed but the latest ‘version’ is 0.2.1-wip
maybe this error is related
Definitely, I thought I had uploaded the fixed version, but apparently not. Below is a version that won’t have this issue.
