Rhino MCP platform
I have rhino-mcp-platform (0.3.0) installed. When I type mcpstart into the command line in Rhino 8, I get an “Unknown command” error; however, it is recognized in the Rhino Beta version. Why is this happening? I would like to work in Rhino 8.
If you run _McpStart with the _ does it work?
I think if you can run SystemInfo and paste it here that’d be great.
I entered it into the command line with an underscore, but it doesn’t work (Unknown command: _McpStart)
Rhino 8 SR35 2026-9-8 (Rhino 8, 8.35.26251.13001, Git hash:master @ 3645d710f50175d8ebcf404aded5b042a481c23e)
License type: Commercial, build 2026-09-08
License details: Stand-Alone
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.20
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 2GB, Driver date: 12-1-2025 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
    Primary OpenGL: NVIDIA GeForce RTX 3060 Laptop GPU (NVidia) Memory: 6GB, Driver date: 12-2-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 591.44
Integrated accelerated graphics device with 4 adapter port(s)
  • Secondary monitor is laptop’s integrated screen or built-in port
  • Secondary monitor attached to adapter port #1
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-2-2025
Driver Version: 32.0.15.9144
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Users\User\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\PlexusPDM\PlexusPDM.rhp “PlexusPDM” 1.0.0.0
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.5.1.0
C:\Users\User\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Crayon (39629248-4fa6-47b8-83c7-745a7efea259)\1.2.0.0\Crayon\Crayon.rhp “Crayon” 1.0.0.0
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Users\User\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5Conv (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\0.12.0.0028\Rhino 8\D5Conv.rhp “D5 Sync for Rhino”
C:\Program Files\SimLab\Plugins\SimLab PDF From Rhino\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Users\User\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\raven\2.0.22\net7.0\RavenPingu.Rhino.rhp “RavenPingu.Rhino” 0.1.0.0
C:\Users\User\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\RhinoBanana\0.1.14\net7.0\RhinoBanana.rhp “RhinoBanana” 0.1.14.0
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.35.26251.13001
C:\Users\User\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.35.26251.13001
I don’t see Rhino-MCP-Platform installed in that list. Does it show in the PackageManager UI? And/or can you see it in the PluginManager UI?
It doesn’t show up for me in the PluginManager UI
Hi @miguelayora3 .
Try running SetDotNetRuntime command and set Runtime to NETCore.
I wondered thistoo but the SystemInfo says netcore
[quote=“MA, post:4, topic:223610, username:miguelayora3”]
.NET 7.0.20
[/quote]
That’s odd. I would uninstall the Plugin from the package manager. Restart Rhino, check it’s uninstalled, and if so, re-install it.
I already tried it and it didn’t work
@Japhy pointed out that the plugin uses net8.0, but your Rhino is on net7.0. If you run SetDotNetRuntime as @bimolicense suggested but change the NetCoreVersion to net8.0 or higher.
