Rhino (Mac) Viewport Camera and Axis Sync Failure During Model Rotation
When working in Rhino for Mac, rotating the model by 90 degrees causes the viewport camera directions to get scrambled and the axes to function completely in reverse. For example, when the model is rotated 90 degrees, the surface that should be on the right side does not align correctly, while the Front View ends up showing the back of the model. If you try to fix this by rotating it -90 degrees to get the front side into the correct angle, the Right View then shows the left side of the object (or the reverse); in short, the camera directions, viewports, and world axes become completely out of sync.
How can I get the correct angles that I want? I don’t want a custom camera angle; I just want it to work properly.
You’re misunderstanding the viewports, it seems to me that it works exactly as it should, for what is worth, you can also set the view to Back and Left if you need to
