Rhino Locks up when accessing options
Very often when I type Options to access the Rhino Options window, Rhino will lock up and I am forced to close the the program, losing all my work.
There isn’t a clear pattern that I can pickup but it seems to happen after the program has been open for a few hours. If I try the command right after opening the same file that crashed the window pops up right away.
It is also not file specific as I’ve had this happen while working in different files
Hi NavArch,
Please run systeminfo in your Rhino command line and post the results. Thanks.
Rhino 8 SR30 2026-3-23 (Rhino 8, 8.30.26082.23001, Git hash:master @ abea9e77e9bb144e00d8281bfa44e613abd9d918)
License type: Commercial, build 2026-03-23
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 64GB)
.NET Framework 4.8.9310.0
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 3-6-2025 (M-D-Y).
Integrated graphics device with 3 adapter port(s)
  • Secondary monitor is laptop’s integrated screen or built-in port
  • Secondary monitor attached to adapter port #1
  • Windows Main Display attached to adapter port #2
    Primary OpenGL: NVIDIA Quadro RTX 3000 (NVidia) Memory: 6GB, Driver date: 8-4-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 580.92
Integrated accelerated graphics device with 4 adapter port(s)
  • Video pass-through to primary display device
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-4-2025
Driver Version: 32.0.15.8092
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.30.26082.23001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.30.26082.23001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.30.26082.23001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.30.26082.23001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.30.26082.23001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.30.26082.23001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.30.26082.23001
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Calc”
C:\Program Files\Rhino 8\Plug-ins\NamedPositions.rhp “Named Position”
