Make and model of computer? If laptop are you running on battery or with power brick connected?
MSI GS66, i9-10980hk, RTX-2080s Max-Q, 32GB Ram.
Always running on power brick connected, checked in both BALANCED and PERFORMANCE mode.
Quickly googling âMSI GS66 wifi issuesâ returns various problems with the wifi on this laptop (like running games stopping the wifi - great for a gaming laptop!).
Things to try based on whatâs out there: Turn off the Killer features and/or remove the Killer s/w. Replace the drivers with appropriate Intel ones if possible. Run wi-fi on the 2.4 band, not the 5 and/or change the wifi channel on the router.
A more thorough search may turn up further ideas.
If other people have this problem it would be helpful if they post their computer details. Conversely, if anyone has the same computer but does not have problems an exchange of configuration details may help nail this.
Cheers
Jeremy
Fortunately, my laptop does not have the WiFi issues you mentioned, even under heavy loads in 3ds Max and Vray renderings.
I called the MSI service centre and they asked me to change these settings in the NVIDIA Control Panel and it worked for me:
- Preferred graphic processor: High-Performance NVIDIA Processor
- Threaded optimization: ON
The problem seems to be from the Nvidia graphics card driver settings, which will be fixed by changing these settings!
Thank you so much!! it seems to have solved the problem for now, been wondering what was causing the wifi issue and restarting routers
Hi all, I have a new MSI GF63 Thin 9SC laptop and was having this same issue after installing the Rhino 7 evaluation version. I tried all the suggestions in this thread and nothing worked. After much searching through online forums and a 1.5hr call with MSI service center, I have found a solution that works for my laptop. Initially I was connected to a dual band network while trying to run Rhino and was connected to the 5 GHz band which was causing the connection issues. Changing to the 2.4 GHz band is the fix.
*Open Device Manager
*Open the Properties for your wireless driver under Network Adapters - mine is Intel(R) Wireless-AC 9560 160MHz
*Go to the Advanced tab
*Scroll down to Preferred Band and select âPrefer 2.4GHz bandâ from the drop down menu
You may need to restart the device for the change to take effect. Mine immediately switched to the 2.4 GHz band and then when I opened Rhino the wifi connection remained stable.
The post by [michal.tofik.olszewski] on this MSI forum had the solution:
https://forum-en.msi.com/index.php?threads/wifi-turn-off-or-goes-very-low-every-time-i-play-a-game.311977/
Hope this helps!
I was wondering if anyone still has this problem and if there are any new fixes. Iâm using a Lenovo Legion 5 with Intel Core i7, and Iâm also experiencing network problems when using Rhino. When I launch the application, my internet connection is so slow that I canât do anything else. At first I didnât realise it was because of Rhino, so I tried every network fix I could find on the internet, but nothing worked. Now that I know itâs because of Rhino (when Iâm using Cinema 4D or other memory-intensive software and I donât have internet problems, so I think itâs specific to Rhino), Iâve tried allowing it through the firewall, changing the settings in NVIDIA control panel, and even changing the preferred band to 2.4GHz, but nothing has worked.
At first it wasnât really a problem, I would close the app when I needed to do a search or something, but now I use V-Ray and itâs a nightmare to download materials and models. Iâm thinking of finding a new 3D program even though Iâve used Rhino all my life. My laptop is brand new and I donât have time to waste on such technical problems.
Thank you in advance for your help !
Hi Sebastien, I have the exact same machine for a few months now and havenât observed this. Any ideas on how I can reproduce or narrow this down? My initial go would be to remove any 3rd party plugins, as well as any anti-virus programs that could be interfering (Windows Smart App Control active?)
Thank you for your quick response. To be honest, I have no idea. I donât have much installed on my computer, I just use Windows Security for anti-virus and Windows Smart App Control is disabled.
Do you have any idea what plugins I should remove? It seems to work fine in safe mode, so maybe thatâs the problem. Also, the only thing Iâve added to Rhino is V-Ray, but I donât want to uninstall it and risk losing some things in my project. But from what I remember, it already didnât work before I started using V-Ray.
I do not have V-Ray. Iâm not a fan of Windows Anti-Virus and have all those apps turned off. Those seem to be the variables at the moment. If starting in safe mode is fine, start with the 3rd party plugins
(and you donât have to uninstall, you can go to file > properties > plugins and enable load protection on a plugin, for testing)
@Japhy V-Ray is the only third party plug-in Iâm using. I tried to disable it (thanks @jdhill), still have the same problem.
About Microsoft Defender do you have any idea of how the issue could be related to that, and what should I use instead ?
Iâm not wholly familiar with the various anti-virus programs, like i said, i donât run them and would just wipe the machine if anything happened. There are some that heavily monitor programs/internet traffic or in the case of Windows Smart App Control restrict.
Check your services, i think V-Ray had service that runs in the background.
Can you post your systemInfo (type in the Rhino Command line) heres mineâŠ
SystemInfo
Rhino 7 SR30 2023-5-10 (Rhino 7, 7.30.23130.11001, Git hash:master @ 92e6bbd255ee28a4168ed9e8d38a590062283b45)
License type: Commercial, build 2023-05-10
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Plugged in [99% battery remaining]
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 7-27-2022 (M-D-Y).
- Windows Main Display is laptopâs integrated screen or built-in port
Primary OpenGL: NVIDIA GeForce RTX 3070 Ti Laptop GPU (NVidia) Memory: 8GB, Driver date: 12-21-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 527.99
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPUâs maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-21-2022
Driver Version: 31.0.15.2799
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp âCommandsâ 7.30.23130.11001
C:\Program Files\Rhino 7\Plug-ins\rdk.rhp âRenderer Development Kitâ
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp âRhino Renderâ 7.30.23130.11001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp âRDK_EtoUIâ 7.30.23130.11001
C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp âRenderer Development Kit UIâ
C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp âSnapshotsâ
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp âRhinoCyclesâ 7.30.23130.11001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp âToolbarsâ 7.30.23130.11001
C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp â3Dconnexion 3D Mouseâ
C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp âDisplacementâ
I tried disabling everything in Windows Defender, but that didnât solve the problem. As I said, I also tried disabling the V-Ray plugin, so it seems that this is not the problem either.
We seem to have more or less the same information on the system, but maybe you will find something !
SystemInfo
Rhino 7 SR29 2023-4-17 (Rhino 7, 7.29.23107.03001, Git hash:master @ 5f05ef3a2eea3d910c4c2fb79ccc75b413d33ca7)
License type: Educational, build 2023-04-17
Computer platform: LAPTOP - Plugged in [80% battery remaining]
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 4-18-2023 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3070 Ti Laptop GPU (NVidia) Memory: 8GB, Driver date: 4-25-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 531.79
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 4-25-2023
Driver Version: 31.0.15.3179
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp âV-Ray for Rhinoâ
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp âCommandsâ 7.29.23107.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp âRhino Renderâ 7.29.23107.3001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp âRDK_EtoUIâ 7.29.23107.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp âRhinoCyclesâ 7.29.23107.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp âToolbarsâ 7.29.23107.3001
Iâm not familiar with your pc, but as itâs a gaming laptop, Iâd look at power management and/or gaming settings that throttle ânon-essentialâ subsystems when the GPU is heavily loaded to reduce the heat load.
HTH
Jeremy
The problem seems to be fixed !
Thanks @Japhy @jeremy5, I canât believe that after all Iâve tried to solve this problem, it was just a feature called âNetwork Boostâ in the Lenovo app, which was supposed to prioritise games over the network, but was just causing problems for me. I also disabled a âWiFi Securityâ setting in the same app, I donât think this was related to the problem, but you never know with those features.
Sorry to have taken your time as this is not really related to Rhino, but I hope it can help others.
Thank you for mentioning it, I wouldnât even thought about this if you didnât post it here. Thank you!
Changed the NVIDIA settings and disabled lenovo optimizations (although couldnt find the network booster).
The problem is now gone, thanks!
Just had this issue occur on my windows 11 PC. I hadnât opened Rhino 7 in a couple months and when I tried opening, it could not validate my license and killed my internet connection. Internet would come back each time as soon as I closed out of Rhino. I spent a few days trying to remedy via the suggestions in this thread.
The problem seemed to resolve itself today when I tried opening Chrome while keeping Rhino open and then clicking Run Network Diagnostics from the Chrome browser. It listed a Default Gateway error and prompted me to restart my router, which I tried several times before with no success, but for some reason resetting it this time while keeping Rhino open seemed to resolve the connection error and I was able to validate my account.
I had also reset my network adapters, performed a network reset (via Advanced Network Settings menu), and manually updated my Wi-Fi Driver, Realtek Gaming 2.5GbE Family Controller Driver, and Xbox Wireless Adapter Driver, but I did not see immediate results - only after I restarted the router with Rhino still open did things finally correct themselves.
