Hi, I’m trying to edit two SubD objects and one polysurface at the same time with a cage. After the first couple of changes to the cage points, one of the two SubDs (always the same one) gets released from the cage, and further edits to the cage only affect the remaining SubD and the polysurface.
I can re-add the subD to the cage, and then a change to the cage control points will show a preview of that subD changing as would be expected, BUT if I release the control points and make it do that change, the change is only applied to the other subD and to the polysurface.
SelBadObjects does not turn up anything.
My Rhino system info:
Rhino 7 SR6 2021-5-7 (Rhino 7, 7.6.21127.19001, Git hash:master @ aec74c050f3ca28ab3cfd6882e9453a52366a9b7)
License type: Educational, build 2021-05-07
License details: Cloud Zoo
Windows 10.0.17763 SR0.0 or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: AMD Radeon Pro VII (AMD) Memory: 16GB, Driver date: 2-24-2021 (M-D-Y). OpenGL Ver: 4.6.14761 Compatibility Profile Context FireGL 21.Q1.1 27.20.14540.3
> Accelerated graphics device with 8 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 2-24-2021
Driver Version: 27.20.14540.3
Z-Buffer depth: 24 bits
Total Video Memory: 16368 MB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.6.21127.19001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.6.21127.19001
Thank you!
