Rhino isn't saving or letting me export my work
This thing keeps popping up when I try to save or export. I have the updated rhino 7 and am logged into the correct VPN for rhino. I don’t know what is wrong?
Hello- Please run the systemInfo command in Rhino and copy/paste the results here.
system info.txt (10.3 KB)
is this an eval or purchased license?
I’m seeing this-
Rhino 7 SR14 2022-1-10 (Rhino 7, 7.14.22010.17002, Git hash:master @ d8a2d020be8cb487bfc091316ef32170cfc7eddb)
License type: Undefined, build 2022-01-10
License details: Stand-Alone
which indicates something wrong with your license.
if you own this license, open rhino and go to preferences>licenses>change my license.
when the dialog pops up, click options, then “remove my license”
rhino will close.
reopen it then when the licensing dialog pops up, click options and either log in if you are using an account, or enter a license key if you are installing standalone.
if you are using an eval, has the eval expired?
I’m using a license from Arizona State University given to me as a student. I also can’t find the licenses under preferences even after I look it up in the help tab.
found it
got it thanks
