Dude ![]()
Your skill for detail is supernatural.
My ability to create details is no greater than yours or anyone else’s, but I am a very patient person.
Patience is the most important quality in my work, because modeling pieces like these is extremely time-consuming. Sometimes, designing and modeling a complete furniture set can take anywhere from two to three months.
InflateCrv is a good tool, but I don’t think it can replace precise NURBS modeling techniques when it comes to the complex details found in classical furniture. Of course, perhaps it doesn’t have all the capabilities yet.
For now, though, I’d rather use software like ZBrush than rely on this command.
I do almost 100% of my work in Rhino, without using any plugins. In terms of time, I don’t find much difference between Rhino and software like Maya or ZBrush. Of course, it also depends on the designer’s speed and level of expertise.
If I were modeling a human face or anatomy, I would definitely use ZBrush, as in the example below. This particular piece is quite old; I think I created it around 15 years ago. The face wasn’t modeled in Rhino, but I did all the remaining modeling in Rhino.
my jaw dropped seeing all these designs, they look so realistic! Great work!
I never considered using Rhino for the full modelling job, but I take my hat off to you!
great work!!
Hi
Thank you… ![]()
In my opinion, there are very few software packages that can compare to Rhino. It may not yet be fully developed in certain areas, but with the continuous improvements being introduced in its newer versions, I believe it will become a complete and nearly flawless platform in the near future.
I don’t usually comment on posts but these renderings are incredible! Keep up the good work.
It looks cool ![]()
I have a problem that I’d like to ask about.
Let’s say I’m designing a furniture collection. Some components are shared between different pieces. For example, the leg of a chair might be identical to the leg of a coffee table or a side table.
For this reason, when I finish designing one piece, such as an armchair, and move on to designing a sofa, I often reuse certain components from the armchair, either directly or with some modifications, in the new sofa design.
When doing this, I don’t change the layers of those components. In other words, they remain on the same layers with the same names as in the original file.
The problem I’m experiencing is that whenever I copy a component from another file using Ctrl+C and Ctrl+V, the number of times I can save the new file normally seems to decrease.
For example, I might be able to save my file five times without any issues, but on the sixth attempt, a warning message appears saying that the file cannot be saved because it is in Safe Mode, and that I need to use Save As instead.
This has resulted in my project files becoming increasingly long and cumbersome.
I’ve been struggling with this issue for quite some time, but I haven’t been able to find a solution.
I’d really appreciate any advice or suggestions from anyone who has experienced a similar problem.
One more important detail: the Safe Mode option under General Properties is not enabled, so it doesn’t appear to be manually activated in the file settings.
This is a safety to assure you do not accidently overwrite an existing or open model. Simply do a saveas and save it with a different name and all should be well.
Dear Kyle
The problem is that this message keeps appearing repeatedly while I’m working on a project. If I use SaveAs every time, I end up creating multiple copies of the same project with different names. Over time, this creates a large number of unnecessary files and takes up a considerable amount of hard drive space.
I understand the safety purpose of this feature, but I believe there should be a way to prevent this warning from appearing repeatedly without having to create a new file every time.
do you have the other file that you are using parts from open at the same time?
are you using blocks that are referenced back to the original file?
No, neither of those. I don’t keep the other file open, and I don’t use linked or referenced blocks.
Ali, I’m sending you a pm
Now you’re just showing off… ![]()
– Dale
I’ll take that as a compliment! ![]()
Thank you dear Dale ![]()
