If you are running Rhino inside of AutoCAD, you should be able to use AutoCAD’s .NET API from the Rhino Python Editor or ghpython.
We have only just started this project with a few samples and have only tried with one version of AutoCAD. This should in theory work with other versions as long as you work with that version’s SDK to write an add-in.
Dear Sir
in latest Version have many update components different from the tutorial doc, really confuse when practice, I was much time spending to try the update thing, I hope u attach a new method of update version for exchange,
now I am stuck at “Creat Appearance asset of material” it so much different the old Version, with only 3 Input plugin
