Does rhino-insid support Chinese?,I am using the revit 2018 Chinese version, rhino wip(7.0.19267.14135). When I click rhino in revit to load the plug-in, the following prompt appears: rhion authorization manager initialization failed, sending -200 error, rhino will not run
This is normally a conflict with another existing Revit plugin. What other plugins do you have running in Revit?
Here is an article on known issues: https://github.com/mcneel/rhino.inside/blob/master/Autodesk/Revit/doc/troubleshooting-rhino-in-revit.md
- Thank you very much. The problem has been solved. Conflict with pyrevit.
Hi
I’m having the same issue. How did you solve it?
