Hello All,
I’m having a particular problem with Rhino Inside on Revit 2021.1.9
Rhino:8.15.2501913001
Revit 2021.2 (21.90.15)
CLR: 4.0.30319.42000(4.8.9300.0)
OS: Microsoft Windows NT 10.0.19045.0
Seemingly Everything is up to date and I can Start rhino Inside and Grasshopper, however I get the following warning when starting Grashopper on Rhino Inside:
Priority: CategoryIcon { Could not load type ‘System.Resources.ResourceManager’ from assembly ‘System.Runtime, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’. TypeLoadException }
Everything seems to work, however there’s a UI problem where a lot of the tabs from Grasshopper are not shown, especially the Revit Tab, which is a big problem for me, could you please assist me?
In talkong to a colleague I was able to find out that Rhino 8 Standalone and Rhino 8 on rhino inside appear to be running on different .NET Runtime versions, but I dont know if this is a problem.
Thanks for your help
Edit: I did some further testing and when selecting Rhino 7 I get no error messages only on Rhino 8, of course I still want to be able to resolve this and be able to use Rhino 8
