Rhino inside revite
first thanks in advance for any help. I just started using Rhino Inside Revit,I am a beginner… ،However, I cannot select any elements created by rhino in Revit even though they are visible. I tried to see if I can select the line and the cube in Revit and il can 't…I noticed that what I do on Rhino I cannot move it in Revit.
What am I doing wrong here? (i use Revit 2024 and Rhino 7
Please do not post the same question multiple times.
@Japhy
Hi
I solved the problem… problem in Revit… must be phase filter : none
Thanks
received_844716010789334
