I wonder if anyone is aware or has tested if Rhino.Inside.Revit is working with evaluation version Rhino (having Revit license) to train basic fundamentals and checking the workflow in an architectural office ;)) THANKS
Hi - as long as the evaluation version is not expired, that should work fine. Are you running into issues?
Hi Wim, is an assumption or did you tried before? Because I would avoid, as you said, running into issues once I launch the training ;))
Hi -
That was an assumption on my part - I don’t have Revit to try this.
There is no difference between an evaluation version and a purchased version (as long as the evaluation hasn’t expired).
