Hi All, i m using Autodesk Family Structural Foundation: Footings Rectangle to place into Revit, i had enabled Work-plane base in the family and untick ‘Always Vertical’.
i m using a work plane to drive the position and rotation of the footings. However, despite how i rotate the plane in grasshopper, it goes to the default Y-axis in Revit.
the white is the intended rotation, the red is referenced from Revit
