Rhino Inside Revit (RIR) - Create a 3D Curve Beam in Revit
Hi All,
I had created a 3D line in Rhino and wish to push it into Revit as a pipe beam element.
C is a 3D Curve
T is a circular profile
I received this error. Any idea why?
The requirement is for a Planar curve. I’ll check to see if there is an overload but fairly certain that planar is a minimum requirement.
if I intend to model a 3d tube that is not planar, can you recommend a component to push from Grasshopper into Revit.
Please internalize your curve and post in a GH file. Thanks
