Rhino.Inside.Revit - Rhino version picker
We currently have to support typically 6 versions of Revit and 2 versions of Rhino so we often get the startup popup to select the Rhino version to work with.
Some of our users have automations that are being caught by this popup preventing the automation from running un-manned. The request is whether it is/could be possible to nominate a default version and bypass this interruption, I’m thinking configured in the Revit.ini file or some similar method of configuring, maybe even specified via settings on the RIR tab inside Revit…?
The only work around we can find at the moment is in the newer Revit versions that support Revit Plugin Managers, that they disable RIR so that their automations work, and then just re-enable as needed temporarily, but this is quite an inconvenience…
A default option would be a more elegant solution
Thanks
Hi @Ian_James,
You can pick a default Rhino version from the Rhino.Inside Options dialog.
No Way…!!!
Thank you… :green_heart:
