Rhino.Inside.Revit_PluginManager
Hi everyone!
If Revit crashes when you start Rhino or Grasshopper through Rhino.Inside.Revit, this might help.
I’d like to share an add-in for Rhino.Inside.Revit that lets you turn off loading of installed Grasshopper plugins.
Rhino.Inside.Revit runs inside the Revit process, which ties Rhino and Grasshopper to the .NET version of Revit itself.
Group Revit Runtime Rhino in Rhino.Inside
Group A 2021 – 2024 .NET Framework 4.8 7, 8
Group B 2025.0 – 2025.4, 2026.0 – 2026.4 .NET 8 8
Group C 2025.5+, 2026.5+, 2027+ .NET 10 8 (8.32+), 9
Rhino Runtime
Rhino 7 .NET Framework 4.8
Rhino 8.0 – 8.19 .NET 7
Rhino 8.20 – 8.35 .NET 8
Rhino 8.36+ .NET 10
Rhino 9 .NET 10
*.NET Framework 4.8 is optional for Rhino 8-9
This leads to the following problems with plugins in each group:
Group A:
Revit 2021–2024 runs on .NET Framework 4.8, so Rhino 8 inside Revit also runs on .NET Framework, not on .NET 7/8 like standalone Rhino.
  • Plugins built only for .NET 7/8 don’t load.
  • If such a plugin runs code when Grasshopper opens, Revit crashes.
  • Plugins for Rhino 8 don’t load in Rhino 7.
Group B:
Revit 2025.0–2025.4 and 2026.0–2026.4 run on .NET 8, the same as standalone Rhino 8. This group has the fewest problems.
  • Plugins built for a newer .NET don’t load.
  • Shared library conflicts can occur (see below).
Group C:
Revit 2025.5+, 2026.5+ and 2027 run on .NET 10.
  • Older plugins store their icons in the BinaryFormatter format, which was removed in .NET 10. Because of this, Revit can crash when Grasshopper opens.
  • Old Python components (.ghpy, IronPython 2.7) don’t load.
In all groups:
  • If several plugins use different versions of the same library, only one version is loaded, and some plugins stop working.
  • When Revit crashes, it doesn’t tell you which plugin caused it.
What the add-in does:
  • Checks plugins without loading them and shows which ones won’t work in your Revit version, and why.
  • Lets you turn off loading of selected plugins in Grasshopper inside Revit. Selections are saved as profiles. All plugins stay available in standalone Rhino.
  • Restores old icons without BinaryFormatter, so Revit doesn’t crash because of them.
  • Preloads the newest version of shared libraries, so plugins don’t conflict.
  • If Revit does crash, at the next start it names the plugin that caused it and offers to disable it.
Important: the add-in does not fix plugins. Its main purpose is to warn you which Grasshopper plugins may crash Revit and to let you exclude them from loading. A plugin that is incompatible with your Revit version stays incompatible until its author releases a suitable version.
Supports Revit 2021–2027, Rhino 7, 8 and 9.
GitHub: GitHub - GCPDdetYakub/RIR_PluginManager: Revit add-in for Rhino.Inside: selective Grasshopper plugin loading, icon recovery and shared-library preloading for Revit 2026.5/2027 (.NET 10) · GitHub
Thanks, I’ll do some testing.
The .net environment is particularly difficult to keep up with for plugin/addin devs right now with the latest Revit 2025 & 2026 moving to .netcore 10.
Unfortunately some old, widely used plugins will need to be updated or removed to keep Revit usable.
