Here’s a link to the previous daily build.
Thanks! FYI the new build works with Rhino 7 but does not load with Rhino 8. Sent details via email. Using latest WIP for Rhino 8 and latest update for Revit 2023. Tried uninstalling some Revit plugins but same issue. Also did a clean install of RIR, removed through windows, restarted and then did clear Rhino install.
I got it to work with the older version. I can start troubleshooting later on in the week. Right now I just need to finish something. I thought I uninstalled most of the revit plugins but can double check and see if that solves the issue.
Latest version of RiR requires Rhino 8.0 (not WIP nor BETA) to load.
If you want to use it with Rhino 8 you should have a Rhino 8.0 installed on your computer, you can keep your Rhino 7.0 installed without problem.
Please download it from here.
Hello RIR team,
I am looking for the RIR version that is compatible for the following setup:
Rhinoceros 7
• Version: 7.18.22124.3001
• Path: 'C:\Program Files\Rhino 7\System'
Autodesk Revit 2022
• Version: 2022.1 (22.1.1.516)
• Path: C:\Program Files\Autodesk\Revit 2022
• Language: English_USA
My organization has a strict IT policy where we are only allowed to use software versions that are available from our app store. I can create a ticket to request for a newer version of Rhino 7 but it will take a lot of red tapes to make sure the request make it.
Let me know if this is possible
Hi @tuah.hamid,
The latest requires Rhino 7.28. I think is worth to create this ticket
But meanwhile, for this setup the maximum RiR that you can use is v1.12.
There are a lot of fixes and improvements since then.
See release notes.
Hello there, i use this thread cause i’m looking for an older version of Rir.
As student i’m using Revit 2025 and Rhino 8.5 but the latest version of Rir requires Rhino 8.11 or above. Is there a way to get Rir 1.2289 ? which should be the version that works with rhino 8.5 and revit 2025.
Thank you in advance for your help.
You’ll need to be on the latest Rhino 8 and Rhino.Inside.Revit to run in Revit 2025
I see but , i can’t get the latest version of rhino atm , so i’m wondering if i could solve it with an older version of Rir
