Im trying to place a foundation pile using the ‘add foundation (isolated)’ component, with a pile family loaded from the linked Revit file (im working in german).
I can place the location in x and y with a plane and the level input seems to give the bottom end of the pile but im struggling to work out how to set the top of the pile. It seems to fix itself automatically to a certain level existing in the Revit file but I cant seem to specify which one.
Any ideas how to control this?
Is the problem that this component is designed for a family with a set depth, rather than one whose top and bottom heights are linked to levels?
Ich kann gerade nicht nachschauen aber soweit ich mich noch erinnere musst du einen ElementParameter hinten dransetzen und darüber den Wert für die Ebene überschreiben, je nachdem wie dein Fundament erstellt wurde, denn normale Fundament habe nämlich nur eine Ebene und die Höhe wird über den Typ gesteuert.
I can’t look it right now, but as far as I remember you have to add an ElementParameter and then overwrite the value for the level, depending on how your foundation was created, because normal foundations only have one level and the height is controlled by the type .
It sounds like an associated parameter? If you post the family we can take a look.
Thankyou both very much for the comments, I havent had a chance to test it yet but will reply as soon as I can, and post the family if its not working !
