Rhino.Inside.Revit - Family types of revit into rhino block
I’m looking for a way to import revit families with the same types into rhino as blocks, For example, all the family windows with the same type will be corresponding to one rhino block. It is important that the windows is not exploded as group of mesh, but it keeps its element geometry. I’m using Rhino.Inside.Revit. Do you have some advice? thank you in advance
Hi Rhino Team V..,
Place an instance of each type in Revit.
Bake into Rhino, it will be a block of similar name. Depending on your workflow you may want a rename script in Rhino.
