Rhino Inside Revit : Detail Group
Hi All,
I had been using RIR component to push line and text into Section View. My current question is
  1. Why, when I group text (labelled in blue), it is not rotated properly?
  2. Is there anyway after creating the group, delete the element that has been injected into the section view?
  3. When I disable RIR: Add Detail Group, the group is gone from section view?
my current workflow is I have a host elevation view, which contains text and line, i wish to group them and update from time to time. Then this group will be copied to elevation A and B with crop view enabled
@jia.yeap Can you attach the grasshopper File?
