Rhino.Inside.Revit clashes in Revit 2027
Hi @Japhy ,
RiR crashes when I use Revit 2027. I can initialize Rhino and I can type command Grasshopper to load Grasshopper. But I encounter error below when I click on Grasshopper icon directly in Revit.
once I load grasshopper from Rhino command without using the GH icon from Revit Ribbon, then I can open Grasshopper using GH icon in Revit without error. The below error occured only if I start to initialize GH directrly from Revit 2027.
I have tested it with Revit 2024 and 2026, i do not have same issue in Revit 2024 and 2026. This happens only in Revit 2027.
Is there similar case from someone?
Thank you in advance.
Hi Junghwo!
Revit 2027 is running in .netcore 10, so this is most likely a plugin (gh/rhino) that needs to be recompiled to run in microsofts latest.
This is going to become very apparent when Revit releases .netcore 10 versions of 2025 and 2026 here in few weeks.
Hi @Japhy
thank you for your support as always!
