Rhino.inside.Revit 2025 WIP installer available
yes I found multiple files (folders) in the addin location…I’m just cleaning up everything and reinstalling the plugin…
…yes it works :wink:
Hello i am having the same issues. Nothing happens when i install from the latest download link.
Hi Jack,
Please ensure you are on the latest Rhino, Rhino.Inside.Revit and Revit versions.
If that doesn’t do it for you, you may have a plugin conflict preventing Rhino from loading inside Revit.
Thanks Japhy. Apologies- i followed that- no plug ins come up. I dont think the installer is working. I updated revit to 25 and i have rhino 8. After installing the rhino.inside it doesnt show up in my apps.
What is your Rhino version? (run SystemInfo in Rhino and post the result, thanks)
Rhino 8 SR12 2024-10-8 (Rhino 8, 8.12.24282.07001, Git hash:master @ 2f42167325d83e0da0f3fe08e796c2b26e602bc5)
License type: Commercial, build 2024-10-08
License details: Stand-Alone
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [77% battery remaining]
Primary display and OpenGL: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 4-30-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.92
Primary OpenGL: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 4-30-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.92
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 128MB, Driver date: 2-5-2024 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-30-2024
Driver Version: 31.0.15.4692
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.12.24282.7001
Everything looks ok in your systeminfo.
Can you post a screenshot of your Revit Ribbon??
Any news with this problem?
Still have this error in one file. I think this file was first created in Revit 2024 before update it to Revit 2025. The only solution is to disable Revit inside Rhino. Latest Revit has an add-in manager itself where you can enable-disable plugins.
Τhe strange thing is, there is no Steel add-in there also
Hi Japhy,
where can i have access to the wip for rhino inside revit (using a rhino 7 and revit 2025)
Hi Abu,
Unfortunately the updates to the .netcore in Revit 2025 are not compatible with Rhino 7 and can not be ported.
Thank you for that, i do have rhino 8 tho. would that work?
Yes, Rhino 8 running .NetCore 7 (the default) does
Thank you. where can i have the Wip for rhino 8
You can download the latest here.
https://www.rhino3d.com/inside/revit/1.0/
Check out the user guide as well. Rhino.Inside®.Revit
Hello.
Does this mean, with my Rhino 7, that I need Revit 2024 or an even earlier version to run Rhino.insideRevit?
Thanks
Hi Keri, Rhino 7 will work in all supported Revit versions except for Revit 2025, which runs on a the newer microsoft .netcore.
hi japhy , may i know is RIR available for revit 2025 now?
there is no RIR tab ,after i install RIR
THANKS
: remove and reinstall , and now available now, thanks
Hi @Japhy ,
Just downloaded and installed RhinoInside.Revit_1.29.9186.27799
I don’t see the tab in Revit 2025.3
I have Rhino8 SR 16
Clues?
Edit: A few times uninstall + reinstall seemed to fix it magically..
