# Rhino.Inside Panels not Showing
**URL:** <https://discourse.mcneel.com/t/rhino-inside-panels-not-showing/141797>\
**Category:** Rhino.Inside\
**Tags:** windows, rhino7, wpf, rhinoinside\
**Created:** [April 28, 2022, 12:34pm UTC](https://discourse.mcneel.com/t/rhino-inside-panels-not-showing/141797 "2022-04-28T12:34:15Z")\
**Posts on this page:** 1\
**Showing post:** 18
<div class="post-metadata">
**Author:** ![stevebaer](https://sea3.discourse-cdn.com/mcneel/user_avatar/discourse.mcneel.com/stevebaer/32/473567_2.png) [@stevebaer](https://discourse.mcneel.com/u/stevebaer)\
**Post date:** [June 10, 2022, 9:26pm UTC](https://discourse.mcneel.com/t/rhino-inside-panels-not-showing/141797/18 "2022-06-10T21:26:00Z")
</div>
You definitely don’t want the -appmode flag, I can tell you that. The reason panels didn’t show up with that flag enabled is because none of Rhino’s plug-ins were loaded.
> [@JDev](#):
> Any idea on why the **RhinoApp.Idle** event is no longer being raised after I remove that experimental flag?
> Also is there any sample documentation for working with the message pump when using Rhino.Inside?
@kike is there anything special you needed to do to get Rhino.Inside Revit to work properly with regards to the message pump?
_[View the full topic](https://discourse.mcneel.com/t/rhino-inside-panels-not-showing/141797)._
