Rhino.inside old version help
Hi, our partner strictly limits us to use Revit 2020.2 for compatibility, but the latest Rhino.Inside.Revit fails to load. Could you please share a download link for an older version (like v1.0 or v1.12) that works natively with Revit 2020.2?
Hi Shitong Li,
We haven’t dropped Revit 2020.
If you have everything loaded but its still not showing make sure the manifest is here..
C:\ProgramData\Autodesk\Revit\Addins\2020
RhinoInside.Revit.addin
<?xml version="1.0" encoding="utf-8"?>
<RevitAddIns>
  <AddIn Type="Application">
    <Name>Rhino.Inside</Name>
    <Assembly>RhinoInside.Revit\RhinoInside.Revit.Loader.dll</Assembly>
    <FullClassName>RhinoInside.Revit.AddIn.Loader</FullClassName>
    <AddInId>02EFF7F0-4921-4FD3-91F6-A87B6BA9BF74</AddInId>
    <VendorId>com.mcneel</VendorId>
    <!--<VendorDescription>Robert McNeel &amp; Associates</VendorDescription>-->
    <VendorDescription>
      <![CDATA[https://www.rhino3d.com/inside/revit/1.0/]]>
    <AllowLoadingIntoExistingSession>false</AllowLoadingIntoExistingSession>
  </AddIn>
</RevitAddIns>
Thanks Japhy!
I managed to grab RhinoInside.Revit_1.21.8913.17015.msi from our server backup, and it’s working great now on Revit 2020.2. Weirdly enough, this is on the exact same PC where installing version 1.35 didn’t show the Rhino.Inside tab at all. No idea why or how that happened, but at least it’s working .
Out of curiosity, I upgraded to the latest version again. Turns out the RhinoInside.Revit.addin file was indeed missing from the C:\ProgramData\Autodesk\Revit\Addins\2020 directory—even though it existed in the older version (1.21). I manually added the file using the method you provided, and now the latest version is working perfectly too! Awesome! Thank you so much for your reply. Love you guys, once again!
