While using Rhino Inside, I have found out that some functions in the RhinoCommon API work differently from the normal Rhino environment. Some of these functions are
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Curve_Offset.htm
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Curve_Extend_1.htm
For example
Rhino.Geometry.Curve lc = new Rhino.Geometry.LineCurve(new Rhino.Geometry.Point3d(0, 0, 0), new Rhino.Geometry.Point3d(3, 0, 0));
var offset = lc.Offset(Rhino.Geometry.Plane.WorldXY, 10, 0.01, Rhino.Geometry.CurveOffsetCornerStyle.Sharp);
Console.WriteLine(offset)
This script prints the resulting offset line in normal Rhino environment. But in Rhino Inside, the output is null. What could be the issue?
