Rhino Inside, Grasshopper baking Elements - Arctic mode shows texture :/
Hi!
I baked geometry from Revit into Rhino using RhinoInside, but the display doesn’t seem to show a white render when I’m on Arctic and still manages to keep the textures - Has anyone solved this before?
Hi Mahmoud -
Can you post one of those objects?
Hello Wim, the green Walls are all part of the problem. That color is neither an object color nor a layer color, neither a material
The only solution currently to this would be destructive (loss of original color and blocks)
RemovePerFaceColors
Works.Thank you Japhy!
