Rhino.Inside for Revit 2027 not working
I am running Rhino.inside 1.35.9651.15514.
Revit 2026
Rhino 8.21.25188.17001
When I run the Rhino.Inside installer it reports that it installed successfully. I can see it installed in Windows “Add or Remove Programs” However, when I launch Revit 2027 I should see Rhinoinside in the file menu but I do not.
I do see C:\Program Files\Autodesk\Revit\Addins\2027\RhinoInside.Revit
so it does seem to be installed.
Please confirm you are on the latest Rhino and Rhino.Inside.Revit.
Hi, do you mean Rhino 9 (WIP)?
The latest 8 works in 2027 as well.
Thanks! I’m going to start over try installing everything again.
