Hello everyone,
I am trying to import a facade from Rhino to revit using Rhino inside and I’m wondering what the best approach is.
I have 189 panel types.
However, they still have very detailed types, based on which face of the building they are on, the level, their location in relation to the interior function (living room/ bedroom) and size.
I have them as blocks in Rhino and these types are the names of the blocks. Each block consists of three blocks itself: 2 window types and the panel hosting it.
Now my question is:
How can I create Revit types from these block names that I have?
What’s the best way to import them? I was thinking of importing them as components (based on their location). I thought of adaptive components as well, however when I deconstruct the panel block, each panel type has different number of points. So I don’t think it would work well.
Thank you for your response. I uploaded a portion of the facade using the link you shared.
The elements are not going to be changed later in the Revit model. They’re going to be used for scheduling, final drawings, and renderings. We are at the final stages of the project.
Thank you Japhy! This is great! I have some questions about the naming convention, but before that, the code runs into a problem and it can’t create direct shapes of some of the elements and I think because of this it will not create the tags and Block_names either. Do you have any idea what’s causing this and how I can solve it on my device?
