Rhino.Inside does not show in Revit ribbon but is installed and enabled
Hi! I just installed Rhino.Inside a few hours ago and I installed my Revit (educational) just last week. Both are the latest versions. I’m using Rhino 8 (8.28.26041.11001, 2026-02-10).
Upon first installation of Rhino.Inside, a pop-up showed up, to which I allowed the addition of the add-in. I thought I was all good to go. However, I noticed that the Rhino.Inside did not show up in the ribbon. I have tried uninstalling and installing the add-in a couple of times, and restarting my machine each time. Nothing has changed. I tried disabling the other add-in I had (PyRevit) and reinstalled Rhino.Inside and the machine, and still nothing.
I checked the add-ins manager in Revit and it’s enabled. Rhino.Inside is also installed in my machine
@Banana_Sho which revit version are you using ?
Please try the following
hi! im using Revit 2027.2. i have also tried the solution in that comment and it did not work
Have you tried Rhino 9
it’s still in progress. i went to the website an i cant download
try from here. you can use it with the existing Rhino 8 license
Hi @Banana_Sho,
Revit 2027 requires Rhino 8.32 or above.
You can update it from the Rhino Options dialog.
