Rhino.Inside. Demension to the wall finish not to the core
Hello there, I wonder if there is an easy way to assign the dimensions to the wall finish instead of the core. Thanks
Not at this time. That would require a pre-configuration for the dimension, where the walls references were calculated and filtered for the desired locations.
