Rhino.inside.autocad in Autocad 2024 (German language version)
I have installed rhino.inside.autocad in Autocad2024 (German language version)
everything is installed and rhino.insdie tap is there in the ribbon.
When I click on rhino or grasshopper, there is no response from the application.
can anybody support this issue?
Thank you in advance.
Hi @park did anything pop up when you clicked on Rhino?
Do any of the support commands work?
Can you look in the command history and see if RiA posted any error just after startup?
Also in have a look in %APPDATA%\RhinoInsideAutocad\Logs and see if there have been any logs, you can PM them to me if you dont want to share them here.
Thanks
Tom
Continuing the discussion from Rhino.inside.autocad in Autocad 2024 (German language version):
@Tom_Norris this is the error that occures after the installation.
plus ;
when I installed Rhino.inside.ACAD it wouldn’t run at all, after a long AI search it tuned out, that the reference to the file 1.3.6 was not correct named in the Package Contents.xml. It was named 1.3.5 but the files name is 1.3.6 so i overwrote it manually in the xml file. that made the installation run. but not the rhino inside Toolbar work.
The data is located in C:/ ProgrammData/Autodesk/Application PlugIns
Can you try with v1.3.7 (v1.3.6 had a build issue).
Hi @Tom_Norris ,
where can I download v1.3.7?
Those it support AutoCAD 2027 as well?
best wishes,
Junghwo
You can download it from here:
Rhino.Inside.AutoCAD - Rhino & Grasshopper in AutoCAD | Bimorph
yes 2027 version is supported!
for now it works from my machine. Thank you @Tom_Norris
my colleague @Helmut_Hilliges and I will discover features.
we are extremely excited about converting AutoCAD assets to Rhino assets including the dynamic blocks.. Where would be best place to report bugs and questions? Thank you.
Perfect thank You for the support
