Dear all,
i m writing you to ask how to remove an image that i use as background in the perspective view.
I ve drag and drop a jpeg on the perspective view, in order to visuale it as backgroud, but i dont understand how can i remove ?
can i also ask you when i m insering a 3ds block downloaded online,
how is possible to convert it as solid or mesh ?
i mean rhino doesnt recognized the snap on it
could you help me ?
If you’re talking about the Wallpaper feature, you can turn it off in the Properties panel when you have nothing selected and the view active. Or use the “Wallpaper” command.
The only snap that will work on imported meshes is “Vertex.” Reverse-engineering garbage 3ds files off the Internet is not a reasonable thing for anyone to do, you’re better off just modeling it yourself.
Note you tagged your post with “rendering” and “Vray” and it has nothing really to do with either.
yes, i was talking about the Wallpaper feature (i didnt know that this was the right name), and i m looking of this on the properties panel, but i cant’ find it. (i m using italian version and i cant find the right translation).
i ve used wallpaper command and i found the solution,
many thanks.
i wish to have time and the right competence to modelling the furniture that i need,
btw, i usually download them from the design company that provide them.
