I have a problem in starting Rhino for Mac and please refer to the attached screen capture.
Hi - does Rhino start after you click the OK button?
If so, please run the Rhino SystemInfo
command and post the result here.
Please find the systeminfo below, thanks a lot.
Rhino 6 SR17 2019-8-24 (Public Build, 6.17.19236.01022, Git hash:master @ 06b69c5cc21d880aa793a5a7cfd454a66f6213bb)
License type: Undefined, build 2019-08-24
License details: Stand-Alone
Apple Intel 64-bit macOS Version 10.14.1 (Build 18B75) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro12,1
Machine name: jyhwang (3)
Language: en-ID (MacOS default)
Intel® Iris™ Graphics 6100 (OpenGL ver:4.1 INTEL-12.2.17)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel Inc.
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: 24 bits
Total Video Memory: 1536 MB
Graphics: Intel Iris Graphics 6100
Displays: Color LCD (227dpi 2x)
Graphics processors
Intel Iris Graphics 6100 (1536 MB)
Color LCD (1280 x 800)
USB devices
Broadcom Corp.: Bluetooth USB Host Controller
Logitech: G403 Prodigy Gaming Mouse
Bluetooth devices
None
Third party kernel extensions
com.logitech.driver.LogiWheelDriver (1) 356E62A4-AB78-39C1-8C7E-9EB80D899CB1
com.driver.LogJoystick (2.0) B02191E1-23F0-3B9B-BD97-F6173C3C2BD4
com.logitech.driver.LogiGamingMouseFilter (1) C5809EB7-6B3C-3F8E-AFDA-297F0B4AFB83
com.globaldelight.driver.Boom2Device (1.2) 5050B3EC-655D-3B74-BC81-81463887C253
com.paragon-software.filesystems.ntfs (19.4.15) BBCE556D-5DFF-371A-8722-729AC6E7046C
Third party plugins
Rhino plugins
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 6.17.19236.1022
/Applications/Rhinoceros.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 6.17.19236.1022
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 6.17.19236.1022
/Applications/Rhinoceros.app/Contents/PlugIns/Displacement.rhp “Displacement” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/RhinoRender.rhp “Rhino Render” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 6.17.19236.1002
I have the same problem: The program is working but in view only mode - I am unable to safe or export. See system info below:
Rhino 7 SR11 2021-10-20 (Rhino 7, 7.11.21293.09002, Git hash:master @ 972ac562128b307e99f15e56dd11586c73e91ecb)
License type: Undefined, build 2021-10-20
Apple Intel 64-bit macOS Version 11.6 (Build 20G165) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookAir10,1
Language: en
Apple M1 (OpenGL ver:4.1 Metal - 71.7.1)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Vendor Name: Apple
Render version: 4.1
Z-Buffer depth: n/a
Total Video Memory: 10922 MB
Graphics: Apple M1
Displays: Unknown (255dpi 2x)
Graphics processors
Apple M1
Color LCD (1440 x 900 @ 60.00Hz)
USB devices
None
Bluetooth devices
None
None
Third party plugins
/usr/libexec/rosetta/runtime
/Library/Apple/usr/libexec/oah/libRosettaRuntime
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreData.dylib
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.11.21293.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.11.21293.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.11.21293.1002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.11.21293.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.11.21293.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.11.21293.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.11.21293.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.11.21293.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.11.21293.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.11.21293.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.11.21293.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.11.21293.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.11.21293.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.11.21293.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.11.21293.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.11.21293.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.11.21293.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.11.21293.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.11.21293.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.11.21293.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.11.21293.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.11.21293.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.11.21293.9002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.11.21293.9002
It shows your license as “undefined”.
I’d suggest Quit (Cmd + Q) out of Rhino and restart.
Any luck?
I already have a project that I’ve worked on completed. If I quit without saving, will all of my work disappear??
You will not be able to save any work without a valid license running.
Sorry
Having the same problem with a student using our Team Account on a Mac. He’s on the list of having a valid license but has the same error as shown at the top of this topic. I haven’t checked his systeminfo yet. He also has an unsaved project. Any suggestions to repair this and especially to prevent it from happening in the future?
Hi Alan -
It looks to me there is some licensing issue involved in this. I’d recommend to reach out to support by phone, chat, or mail so that this can be dealt with more efficiently. See Rhino - Rhino Support for contact info.
