I’m trying to import a dfx file, SketchUp file, and even a Rhino file into Rhino, but none of them are working. What should I do?
Hi Misuzu,
Lets start with your SystemInfo (this tells us what Rhino version you are using and enviroment)
A file would be ideal as well. Thanks
https://discourse.mcneel.com/t/please-read-this-if-you-are-logging-a-bug-or-issue/173971/3
hi, i’m using rhino7 and also i mean import option doesnt work withing drag-drop but impot-open is still working…
Apologies, SystemInfo is a Rhino command line, please run the command and post the results.
I think I fixed it… Thank you for giving a time!
