I’ve just purchased an MX Creative Keypad and Dialpad combo. The application allows one to place desired icons to label the keys. I’d like to get the proper Rhino Icons for the key assignments. Is there a file of such that can be accessed?
_TestDumpSvgs
might be exactly what you need
Looks like a nifty acessory, I might get one for VSCode
Thanks Callum, but I don’t understand. I typed the command into Rhino but get nothing. Where does one find this accessory?
You should have a folder full of icons on your desktop after you run it
I just checked back in. I usually get an email notification when there’s a reply. I tried running the _TestDumpSvgs again
But I find no folder of icons anywhere. Is this command not workable in the Mac version?
Hi James -
When I run that here in Rhino 8 on macOS, it creates the “rhino_svgs” folder on the desktop:
I see. I’m using V7.
Any chance you’d send me the folder?
Rhino 7 doesn’t use SVG files for the icons. Here’s the Rhino 8 folder:
rhino_svgs.zip (3.9 MB)
Thanks!!
Apologies, I should have asked which Rhino version you were on @JKayten. Glad it’s sorted, thanks for the save @wim
No Worries Callum - you started me on my way in any case.
