Hi there,
I am hatching polygons in rhino and i want to make them associative to the boundary- as per the rhino instructions Im turning history on (record- yes and update-yes) but once I have done the hatch and then edit the polygon boundary the hatch just disappears!
any ideas?
thanks
Jules
That doesn’t happen when I try that here. Could you post the file and your GPU information (a screen shot of Rhino Options > View > OpenGL
thanks Wum, files attached- your help is much appreciated. jules
170302_rhino for windows forum_base.3dm (834.1 KB)
How are you “editing” the hatch boundary? Things that may break the history and make the hatch disappear:
- Moving an element so that the boundary is no longer closed
- Deleting an element that composes the boundary
- Splitting or otherwise modifying a boundary element so that its object ID (what Rhino uses to concoct History) changes
Can you post an example with a history-enabled hatch and an editing routine that makes the hatch disappear?
–Mitch
Hi Jules,
On an unrelated note: you might want to update your GPU driver, it’s dated 9-12-2014.
-Willem
Also make sure to check for Rhino updates.
hi mitch/ wim
I have just tried this on my home (not work) computer and it worked fine- so obviously it a problem with my work computer…I will try updating it and see how I go.
thanks for your help and apologies for the slow reply (been away…)
cheers
Jules
I’m having the same problem is there an official solution to this thing?
