Rhino hangs when script is updated outside of Rhino while it is running
this happens when developing py-scripts in the ScriptEditor.
Run the script. Make it wait for input or whatever, so that the script is running.
Now update the script outside of Rhino.
Rhino hangs.
If the script is stopped and updated outside of Rhino it works fine.
Would be great if this could be fixed. I think the “focus” is somehow lost, so the user can’t click in the scripteditor to reload the script and neither can the user stop the script, this Rhino is frozen and needs to be killed.
Thanks
/Erik
somehow this is not accessible if the script is running.
It actually seems to happen if a command is active in Rhino. Does not have to be the actual script.
The button is working (turns grey when hoover over), but nothing happens.
Quite irritating.
The viewport allows rotation, but not selection.
Also the command window works. So one can issue “save” which is a life-saver.
But restarting is the only full cure as far as I can understand.
/erik
