Rhino-Grasshopper to Etabs
Hi everyone,
I am learning Rhino, and I am trying to export my created model (Using grasshopper) to Etabs. Can you please help to figure it out? I am using Rhino 7.
Thank you
Which plugin or technique are you using to generate Etabs models from Grasshopper?
If it is the Geometry Gym Plugin, then there are some example scripts here that you can use as a basis for getting started, Etabs Examples - Geometry Gym
