Hi!
I was wondering if it’s possible to record a path-on-curve animation on Rhino while animating a Grasshopper slider at the same time? Basically, as the camera rotates around the object, the object transforms through the ongoing Grasshopper slider.
Thanks a lot, AJ
Have a look at Horster
Meanwhile, I found this thread that deals with a similar issue.
is it possible to solve this problem without coding?
