i have a script here that i’m trying to get subobject select working.
per documentation:
GetObject(message=None, filter=0, preselect=False, select=False, custom_filter=None, subobjects=False)
but in autocomplete it’s not showing
Option Explicit
'Script written by Pascal
' RMA
'Script version Tuesday, December 06, 2011
'Rhino.AddStartUpScript Rhino.LastLoadedScriptFile
'Rhino.AddAlias "FinAngle", "_NoEcho _-Runscript (FinAngle)"
Private oldLen, oldAng
If isEmpty(oldlen) Then
OldLen = 1
End If
If isEmpty(oldang) Then
OldAng = 10
End If
'Call FinAngle()
Sub FinAngle()
' Dim sCrv: sCrv = Rhino.GetObject("Select curve", 4, True)
Dim sCrv: sCrv = Rhino.GetObject("Select curve", 4, True, , , True)
If isNull(sCrv) Then Exit Sub
Dim BlnCLosed: blnClosed = False
If Rhino.IsCurveClosed(sCrv) Then
blnClosed = True
End If
'Dim sSrf : SSrf = Rhino.GetObject("Select base surface.", 8)
Dim sSrf : SSrf = Rhino.GetObject("Select base surface.", 8, , , True)
If isNull(sSrf) Then Exit Sub
Dim dblAng, dblLen
dblAng = Rhino.getreal("Fin angle.", oldAng, 0, 90)
If isNull(dblANg) Then Exit Sub
OldAng = dblAng
dbllen = Rhino.getreal("Fin depth.", oldlen, 10 * Rhino.UnitAbsoluteTolerance())
If isNull(dblLen) Then Exit Sub
OldLen = dblLen
Dim aEdit: aEdit = Rhino.CullDuplicatePoints(Rhino.CurveEditPoints(sCrv))
Dim apar: apar = Rhino.CullDuplicateNumbers(Rhino.CurveEditPoints(sCrv, True))
Dim aLines, blnFlip, aItems, aDef, n, Flipped
aItems = array("FlipAngle", "No", "Yes", "FlipNormal", "No", "Yes")
adef = array(False, False)
n = 0
Flipped = 0
Dim tempsrf, intAng
intAng = 1
Do
If n <> 0 Then Rhino.DeleteObjects tempSrf
aLines = AddLines(sCrv, sSrf, aEdit, aPar, dblLen, dblang)
tempSrf = makeSrf(alines, blnClosed)
Else
End If
blnFlip = Rhino.GetBoolean("Set options:", aItems, aDef)
If Not isArray(blnFlip) Then Exit Sub
If BlnFlip(0) = True Then
dblAng = -dblAng
intAng = 2
Else
intAng = 1
End If
If BlnFlip(1) = True Then
If intAng = 1 Then dblAng = -dblAng
Rhino.UnselectAllObjects()
Rhino.SelectObject sSrf
Rhino.Command "_Dir _Flip _Enter "
If Flipped = 0 Then
Flipped = 1
Else
Flipped = 0
End If
End If
n = n + 1
Loop While blnFlip(0) + BlnFlip(1) <> 0
If Flipped = 1 Then
Rhino.Enableredraw False
Rhino.Enableredraw True
End If
Rhino.DeleteObjects aLines
End Sub
Function makeSrf(alines, blnClosed)
Dim tempSrf
If BlnClosed Then
tempSrf = Rhino.AddLoftSrf(aLines,,,,,, True)
Else
tempSrf = Rhino.AddLoftSrf(aLines,,,,,, False)
End If
makeSrf = tempSrf
End Function
Function AddLines(sCrv, sSrf, aPts, aPar, dbllen, dblang)
Rhino.EnableRedraw False
Dim aLines, edit_pt, start_par, n, vecnorm, plane
n = 0
ReDim alines(Ubound(aPts))
For Each edit_pt In aPts
start_par = Rhino.SurfaceClosestPoint(sSrf, edit_pt)
Vecnorm = Rhino.VectorScale(Rhino.SurfaceNormal(sSrf, start_par), dblLen)
plane = Rhino.CurveperpFrame(sCrv, apar(n))
aLines(n) = Rhino.AddLine(edit_Pt, Rhino.PointAdd(edit_pt, vecnorm))
Rhino.RotateObject aLines(n), plane(0), dblang, plane(3)
n = n + 1
Next
AddLines = aLines
Rhino.EnableRedraw True
End Function
