Is there a c++ function used to get the cage of the selected poly-surface object? Because I want to use cage vertices control object deformation.
If you have a morph control object, it is possible to get its captive objects. For example:
CRhinoObject* object = .....
const CRhinoMorphControl* morph_control_object = CRhinoMorphControl::Cast(object);
if( morph_control_object )
const ON_MorphControl* morph_control = morph_control_object->Control();
if( morph_control )
int ci, captive_count = morph_control->m_captive_id.Count();
const ON_UUID* captive_id = morph_control->m_captive_id.Array();
if( captive_id )
for( ci = 0; ci < captive_count; ci++ )
CRhinoObject* captive_object = context.m_doc.LookupObject(captive_id[ci]);
if( captive_object )
// TODO...
The SDK does not, however, provide way to find a morph control object given a “regular” geometry object such as a curve, surface, or Brep. It is possible for us to add one. But I would like to better understand what you are trying to do and why. Any details you can provide might be helpful for me.
Thanks for you help. In face I have got a captive object,then I will get the captive’s boundingbox, set the boundingbox as the morph control object.
