Halo, I am trying to make a workflow that transfers Rhino Geometry to Revit window family.
Because it’s difficult to make this special style window family directly in Revit.
I am follow the example video but it’s not working in my case, the last error is “This family requires a host.”
Did I miss something ?
Hi, thanks for the tips. Now iI managed to make a window family but with some errors.
In revit, the warning is “the opening does not cut anything”
In grashopper, the waring is “The opening does not cut anything. {253819, 254537, 254542}” . But this is a pure geometry, there is nothing at {253819, 254537, 254542}
Ideally, the family geometry and the opening curve should be defined centered at (0,0,0) this will be the origin of your family.
Is your opening curve on the reference wall there is in the family?
Yo can allways edit the Family you are creating with Revit and check whats wrong with it.
By the way, I still didn’t find a way to save this new family type as .rfa file.
Now I can only create a new project in Revit, and save as a .rvt file.
@kike Hello, the code is not working with the latest rhino.inside and revit 2021, there is another error “1. No suitable host object is been found”
It looks like a small error about the wall, but I don’t know what he needs exactly. Do you have some idea?
‘New component Family’ collects all the geometry and tries to build a Family out of it.
In the case of openings it needs the family Template aready contains a Host, like a Window or Door template file do.
