Is rhino geometry supported for overhead lines in va yet?
if not would a suitable workaround be to define the rhino geometry as va walls?
Hi @Hunter1,
Not yet. What do you need to do?
You can use the _vaWallFromSolid command to create walls from Rhino geometry
I have some complex objects that are overhead in my floor plans… I’ll just make them ‘walls’ and go from there. Thanks!
